Superchips Flashpaq for JK, Initial Impressions
Computers and chips are not an exact science, meaning that it is not 100%/perfect, sometimes funny things happen/software or hardware does not load correctly or the hardware may be on its way out (chip going bad or connections), The thing to do is to re-boot or in our case reload or reprogram with a new up-date. Even start from the very begining and restart your own PC (sometimes it's like that) you have to restart programs that don't load correctly, the secret is to take you time and let software take it's time in loading or reload software even though it seems it has loaded correctly. Like I say, the many problems I have seen in software and some hardware, The best advice I can give is to shut everything down, wait at least 10 seconds, I usually go 30, and restart everything and start from scratch. Dealing with software takes time and patience and the willingness to start from scratch and even the want to reload the software if thats what it takes. Good luck, if you have to take superchips program off of your PC and start from there (start from the very beginin). Take your time.
I really like the Superchip
Crawl setting is great in the mud/swaps here in FL.
Change the Thermostant to 180* F (thanks JPop) and set the Fan to start at 200*F
Use the Data logging to view the Coolant and Transmision Temp, Voltage, Vehicle speed.
Features SuperChip
Industry leading Jeep tuning
91-Performance
87-Performance
Towing: Heavy Load Use
Mileage XS: Fuel Economy
CRAWL: High low-end torque off-road mode
All tunes work in 2WD, 4WD-HI & 4WD-LO
OFF ROAD FEATURES
Superchips exclusive CRAWL off-road tune
Tire size calibration of speedometer available on properly equipped Jeeps
Transfer case gear calibration on 2005 and newer Jeeps if properly equipped
Axle gear calibraton on 2005 and newer Jeeps if properly equipped
4WD-HI axle lock with auto-disengage safety feature
Tire Pressure Monitoring System threshold adjust
Real time idle control for running accessories
TRANSMISSION
Superchips Optimized transmission performance standard on all Jeeps
Wide Open Throttle shift points tuned on most Jeeps
Shift firmness optimized on all Jeeps
Advanced transmission tuning product available on newer Jeeps allowing for custom shift schedules, firmness and shift points
ADVANCED ENGINE PERFORMANCE
Rev limiter adjustable on 2005 and newer Jeeps
Speed limiter adjustable on all Jeeps
Throttle body relearn available on newer Jeeps
Spark advance settings available on older model Jeeps
Fan temperature on/off available on Jeeps with electronic fan control
Read & clear diagnostic trouble codes standard on all vehicles
NOTE: Features vary be year, make, model and engine. Search by vehicle in question to find out the details. All Superchips tuning products for gasoline-fuled vehicles are either covered under CARB Executive Order number or are in a pending state. All non-racing Superchips tuning products for diesel-fueled vehicles are on the CARB products in progress list pending CARB testing and approval.
Features SuperChip
91-Performance
87-Performance
OFF ROAD FEATURES
TRANSMISSION
Has anybody messed with the shift points?
I found the post by JK@ZA on page 177 with his spreadsheet but didn't see much else. Admittedly, I might have missed a post here or there with the 200+ pages of posts.
The main thing I would like to change is the shift from 3rd to overdrive. I'd like to bump it up a bit so I'm not shifting into OD running around town then jumping right back down out of it.
Anybody else mess with them and had any luck...is it worth messing with?
Thanks
Thanks
Features SuperChip
91-Performance
87-Performance
OFF ROAD FEATURES
TRANSMISSION
Features SuperChip
91-Performance
87-Performance
OFF ROAD FEATURES
TRANSMISSION
The Factory/stock Thermostant is 195*F
http://www.superchips.com/forum/view...hp?f=2&t=10717
In a side note you can now Purchased and upgrade to be able to use the Tuner in two(2) Vehicles -
On the newer tuners, you can buy a additional VIN slot to tune 2 trucks at one.
Ron
_________________
RRAPP@SUPERCHIPS.COM
Ron
_________________
Thanks
Thanks
Hope that helps you.
Anyone else having problems with the SC Easy Update program not filling up the space completely and looking cut off? I have a large white area on the right side of the window when it's running, and the information looks a little cut off.
With gas over 4 bucks a gallon for a long time now, in California, I decided to try the Mileage XS program. Was using the performance 87 tune.
To my disappointment gas mileage seems to have DROPPED, even tho I am also trying to drive more conservatively. I might as well go back to the performance tune.
Anyone have success with the MXS tune?
W/ the 87 tune I get 1 to 1.5 MPG more in the city than w/ the MIleage X -
Guess I will put it back to the performance tune and live with it. At least I get decent acceleration that way.
