Superchips update
Did the update on my superchips tuner and it claims that there is a new feature that allows me to turn off my tpms. When I plugged it into my jeep I couldn't find this feature. Has anyone else have the problem?
You need to install the TPMS Off Road package. Its a no charge add on, but is done through the superchips online store (which you should be able to access through the same app you used to update the software from your computer).
Since you are disabling the system, they have it as a separate add-on so they can have you acknowledge a waiver. Then as noted above, you 'enable' the feature to disable the tpms.
