Superior Gear overhaul
Old Sep 16, 2008 | 05:53 PM
crajos11's Avatar
Default Superior Gear overhaul
I am looking if anyone has a data sheet on specs for regearing im looking for the torque of pinion and much it should take to rotate it and im looking for the torque of the front d30 ring
Old Sep 17, 2008 | 06:21 AM
rabidranger's Avatar
FRONT AXLE - 186FBI
AXLE DESCRIPTION
SPECIFICATION
Axle Ratio
3.21, 4.10
Ring Gear Backlash
0.12 - 0.20 mm (0.005 - 0.008 in.)
Pinion Torque To Rotate - Original Bearings
1.13 - 2.26 N·m (10 - 20 in. lbs.)
Pinion Torque To Rotate - New Bearings
2 - 3.4 N·m (15 - 30 in. lbs.)
Differential Total Torque To Rotate: Pinion Torque To Rotate Plus
0.79 - 1.24 N·m (7 - 11 in. lbs.)
TORQUE DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Fill Hole Plug
34
25
Differential Cover Bolts
41
30
Bearing Cap Bolts
61
45
Ring Gear Bolts
108
80
Pinion Bearing Nut Min - Max
217 - 542
160 - 400
Axle Nut
136
100
Hub Bearing Bolts
102
75
