Supertop NX Twill Help
I was wondering if someone could please help me? I just purchased a Bestop Supertop NX Twill for a 4dr JK and I cannot get it to latch to the hooks on the front window. It sat outside all day in 80 degree weather and is still about 1/2 - 1 inch short to connecting. ANy ideas or suggestions would really be appreciated be the rain comes.
Perhaps release some tension on the tailgate bar or zippers , for now. Usually the fabric needs time to stretch. Go back and forth with different attachment points allowing it to stretch here and there . Other wise watch YouTube installs for "tricks" to this temporary issue. They are meant to fit incredibly tight at first. Patience and perseverance. While the Sun is an idea , others have run the heat while in the Sun. Also try taking the back-side panels off for now and stretch the top and back only. And vise versa , sides and no back. In the end you will have a conforming fit to your keep and hopefully no water leaks. Good luck
What happens when you want to put top down when its hot, and then back up when cool evening comes ? This tight, hard to fasten would be a real pain for Spring, Fall variable temps
