Suspension issues. needing some advice
Old Oct 23, 2010 | 08:16 AM
The_Yeti's Avatar
I have not had a chance to measure it against anything else. today is going to be a day for it.
Old Oct 23, 2010 | 08:18 AM
The_Yeti's Avatar
One thing i do notice i have a bit of a reverse rake.(front sits a little higher)
Old Oct 25, 2010 | 07:32 PM
The_Yeti's Avatar
Checked measured did everything and ended up taking it to a shop for a "free alignment check" they told me i needed to take my jeep to a fabircation shop and put it on a frame machine.
I asked them what was bent or broken they said "nothing it must have been hit hard and shifted sideways" at this point im confused and stated i would have noticed that hard of an impact. Then i was told "well you could loosen the U-Bolts and slide the axle sideways" Are you on crack?
Dumb founded again i explained that if nothing is off and i dont have leaf springs what will a frame machine or ubolts fix? their reply im not sure.
My fix for now i ended up replacing my leveling kit spacer with a 2-1/2 spacer....Untill i can get a full 3" lift
