Suspension NEWB, have some questions
Bumping this up to ask if there's anything else needed with the rubi springs/shocks and leveling kit or will I be alright with just those parts? Also with discos, will the jks 2.5" links be too long or the 2" set be too short?
If you thinking about changing ur suspension is there reason that u want the rubi shocks ?? My advise ... Get the teraflex coil lift and shocks it rides much better.. you will notice
Yes u already have control arms if you look under your jeep the easy once to notice is the lower ones there will be 4 black metal rods two on each side which like the guys here said you don't need to change if your not planing on going above a 3' lift...
mostly you will do it once rather than doing this and changing it again
There are a lot of guys running that. I might get longer brakelines down the road.
Ain't that the truth. I believe Eddie had a diagram of how to measure to get the true height. Then you can decide on how long for the disconnects. Im going to run the ones that come with tf kit for now. I do not do any extreme wheeling....at least not yet.
