Suspension too stiff FT 3"
Old Apr 10, 2008 | 06:32 AM
JK07's Avatar
Default Suspension too stiff FT 3"
looking for professional advice from you guys
I am running FT 3" ultimate with HD coils in the front along with FT M Force Gas charged shocks. The ride is too stiff
installed the Rancho shocks made a little difference but not what i was expecting now i think it is the springs which are really stiff i have 12000 KM on the rig thought they will settle down after a while but no luck
have a arb front bumper winch etc in the front
what should i do wait a little more longer for springs tp settle or should i look to change the springs specially the front is really bad you really feel it on every bump
any help is appreciated
Old Apr 10, 2008 | 06:43 AM
Piginajeep's Avatar
what tires are you running, and the PSI in them?
the HD will be a little stiffer, to help the added weight. Its a trade off. You can always get a set of the normal springs and try that out.
Old Apr 10, 2008 | 06:47 AM
JK07's Avatar
I am running Mickey Thompson 35" MTZ with 35 PSI also I have noticed that the left side of the front spring is kind of bent
Old Apr 10, 2008 | 06:49 AM
flip2spin23's Avatar
do a chalk test on the tires. but thats just probally just how a lifted jeep rides
Old Apr 10, 2008 | 06:51 AM
Piginajeep's Avatar
thats alot of PSI, try to lower your PSI. That'll definetly cause a stiff ride.
I run 26 in my 35's.
Also the spring, the arms may not being adjusted properly, Measure them and make sure they are the same lengths. That will always make your spring bowed.
Old Apr 10, 2008 | 06:53 AM
JK07's Avatar
drove a friends TJ lifted 6" with 37" tires he has rancho adjustable shocks which he dials in accorind to trail conditions but his rig is much softer than mine
Old Apr 10, 2008 | 06:55 AM
Piginajeep's Avatar
Like I said, tires have alot to do with ride quality. Whats his PSI?
Old Apr 10, 2008 | 08:44 AM
G Timmy's Avatar
35 PSI is too much, you should drop it down to like 25-28.
Old Apr 10, 2008 | 08:59 AM
Tyler2786's Avatar
X2 on the psi
I have those exact tires and setup and run 27 psi. Yea, its stiffer then stock, but it feels good to me
Old Apr 10, 2008 | 09:01 AM
Piginajeep's Avatar
it can't be too soft, it'll cause the body to roll and the esp to kick on.
the higher you go, the stiffer it's going to be.
