Swapping E-Fan for viscous fan
Old Apr 10, 2012 | 11:25 AM
ReconJeep's Avatar
Default Swapping E-Fan for viscous fan
Anyone done a swap and got rid of the electric fan? I know other JK owners have had problems with their electric motors due to water intrusion. In my old TJ we tried running an e-fan and had nothing but problems. It was also much less efficient than the original viscous fan, so we swapped back.
Looking down at my 09' JK motor I can see the threaded shaft where the viscous fan would go. That means that on another version of this motor, they are running it with a viscous fan. Anyone know if any other model Jeep, Chrysler or Dodge that runs this engine with the non-electric fan? Getting a shroud is not a problem because the diesel ones have them, and it should be pretty easy to adapt. I've already been looking into it. Any help or insight would be greatly appreciated. TIA.
"Ex Umbris Venimus"
Sent from my iPhone
Old Apr 10, 2012 | 11:41 AM
tslewisz's Avatar
It's a minivan engine usually installed sideways. Good luck in your search.
Old Apr 10, 2012 | 03:32 PM
Redman333's Avatar
Huh? -----;(
Old Apr 10, 2012 | 03:39 PM
Redman333's Avatar
"Ex Umbris Venimus"
Sent from my iPhone
Can you explain to me what you mean by more efficient. Generally speaking electric fans are more efficient as far as gas mileage and horse power.
With that said what I'd do is measure the thread pitch and find a viscous fan that has that thread pitch and then just measure your clearances to make sure that fan fits and there you go.
Old Apr 10, 2012 | 11:51 PM
ReconJeep's Avatar
More efficient cooling. My first check will be to try the diesel JK fan but that will probably useless due to it being an Italian motor. Then I'll try my TJ and WJ fans if the size matches. I have taken all the possible measurements. I was just wondering if somebody had already done this, to avoid all the testing. If nobody has, when I do it, I will post it for others interested.
"Ex Umbris Venimus"
Sent from my iPhone
Old Apr 11, 2012 | 01:00 AM
Lorrel's Avatar
I remember an awful lot of XJ owners were changing out the viscous fans for electric. The stock fan on an XJ did not do its job well after lifting/bigger tires/more weight from bumpers and armor/and winches sitting in front of the grill. I cooled better by going to a H/D 3 core radiator.
Old Apr 11, 2012 | 10:52 AM
ReconJeep's Avatar
JK is quite a different beast than a XJ. I plan to change the radiator for sure since I run an 8274 in front of the grill. E-Fan has to go. Way too unreliable. Different people have different needs.
