Sway Bar Disconnect
Old Mar 6, 2009 | 08:23 AM
JayhawkJeep's Avatar
Veteran: Navy
Default Sway Bar Disconnect
I am looking at buying Sway Bar Disconnects and was looking for thoughts. So far I like the JKS but still weighing my options.
Old Mar 6, 2009 | 08:43 AM
Amway Man's Avatar
I have/had the JKS on my XJ and they work great! A little fragile if you dont disconnect and they are under stress but they are so easy to disconnect and reconnect that if you're going in the rocks - just take it off.
Old Mar 6, 2009 | 09:03 AM
Calypso's Avatar
I had the same question a few weeks ago. David at Northridge 4x4 recommended JKS quicker disco fronts and Currie rears.
Old Mar 6, 2009 | 09:13 AM
leros's Avatar
big fan of the TF ones. i like havin a place to secure the disconnected swaybar w/ out having to use bungees or zipties.
Old Mar 6, 2009 | 10:09 AM
Calypso's Avatar
.....and how does that work?
Old Mar 6, 2009 | 10:42 AM
joneszj's Avatar
Default how do they secure?
pics of them "secured"???
Old Mar 6, 2009 | 10:45 AM
Mark Doiron's Avatar
There's are pins where the QDs are attached when disconnected. Plenty of info/pic's in the write-up:
Teraflex Quick Disconnect Write-up
Old Mar 6, 2009 | 10:47 AM
leros's Avatar
They come w/ posts that bolt on underneath the base of the grill so you can get them up and outta the way.
Old Mar 6, 2009 | 01:59 PM
Veteran: Navy
Decided to go with JKS when I found that they were selling twenty dollars cheaper on EBAY then there website.
Old Mar 6, 2009 | 08:15 PM
doc307's Avatar
You will like them. I am running the JKS on mine.
