sway bar disconnelct
Old Mar 11, 2009 | 07:06 AM
tboth09's Avatar
Default sway bar disconnelct
i dont have a jeep yet but i am looking to get a jk soon so correct me if im wrong at any point. the rubicon comes with a sway bar disconect button whcih applies to stock. if a lift is installed does the sway bar disconect button still apply?
Old Mar 11, 2009 | 07:10 AM
Michigan Mike's Avatar
Short answer...YES! Certainly works on mine.
Old Mar 11, 2009 | 07:11 AM
YellowToy's Avatar
yep. you will just need longer links. most kits give you new links for the rear & you move the rear links (longer than the stock fronts) to the front.
Old Mar 11, 2009 | 07:13 AM
tboth09's Avatar
thanks guys. what lifts are you guys running
Old Mar 11, 2009 | 07:21 AM
I'm running the Full Traction 3" Ultimate (which is actually more than 4") along with the OME Long Travel shocks. The F/T ultimate kit comes with adjustable everything. The F/T monotube shocks are REALLY stiff snd the OME's improved ride quality alot.
Old Mar 11, 2009 | 07:34 AM
tboth09's Avatar
what was the cost for all of that and where did you get it from?
Old Mar 11, 2009 | 08:06 AM
Well let's see. I got the F/T Ultimate from 4WD.com back in August of 2007. If I remember correctly the kit was @ $1850 and 4WD was having a 10% off sale so...well ya'll can do the math. I got the OME-LT's from David at Northridge about 2 months ago and they were $89 each. Labor was all me.
Old Mar 11, 2009 | 08:08 AM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
as stated,swaybar button still works great
