Sway in frontend
has anyone else had this problem after installing a lift kit it hapens while driving going over small bumps in the road or just uneven ground i would like to know if anyone has any ideas
Are you referring to the Death Wobble? Feels like the wheels are going wherever and you have no control?
Could you be more specific with the problem you have? I noticed after my 2.5' lift that my steering was more touchy and required more concentration on the highway. Then after I added 33' tires bumps seemed to make my steering wheel move more, which a better steering stabilizer would probably help with.
Any kind of more aggresive terrain type tire will have that floaty effect, even more so when you start to add more inches to the tire width. The original tires on the X and sahara are much better handleing on the road, just the way it is.
i dont think thats it i had put front and rear track bars in and it went away for about a year and now its back it looks like the front axel is moving left to right i can see scrape marks on the frame from it rubbing
