Swaybar appears to be bent
Old Sep 22, 2008 | 12:20 PM
Conradfreedumb's Avatar
Default Swaybar appears to be bent
I think my sway bar is bent. When I went to put back my links the left side did not want to come down to meet the link. What should I do?
Old Sep 22, 2008 | 12:50 PM
wayoflife's Avatar
JK-Forum Founder
are you sure you were on level ground when you tried to put your links back on? you need to be 100% level or else they won't go back on without some effort.
Old Sep 22, 2008 | 12:55 PM
leros's Avatar
If you're not on level ground but it's close have a friend either lift or push on the corner of the front bumper.
Old Sep 23, 2008 | 08:56 AM
Thanks for the tip. I had totally forgot about that.
Let me give ya'll a little more info.
As I was on the traIl I hit a few bumps suddenly I couldnt fully steer.
The top links on the swaybar were now lowered down. As I took them off and reconnected and re-adjusted it but a little ways down the road it happened again.
Thats when I coulndt get the connected again.
I will try today to connect my longer Rough country ones I just dont want it to happen while im driving on the highway:(
