SwayBar Disconnects???
Old Jun 23, 2010 | 12:24 PM
Mark Doiron's Avatar
Originally Posted by nthinuf
... the problem with [TF] is that they are positioned to where the tires can and will contact them when flexed/turned, ripping out the pins on the trail. Search any of the 'other' disconnect threads for more info on it, but people say they carry lots of spare pins when they go out...
I have not had this problem, and I don't carry spare pins. I think this may be isolated to certain tire sizes/wheel offsets--especially anything close to stock (as already mentioned earlier in this thread).
Old Jun 23, 2010 | 01:19 PM
nthinuf's Avatar
One of the many threads I've seen...
https://www.jk-forum.com/forums/show...ght=disconnect
I have JKS disco's, so no personal experience, just passing on what seemed to be a fairly common issue. Maybe you have the 'new' brackets or pins, or less backspace, or smaller tires, or whatever other difference may be involved.
My guess, 4.5 BS with a sub-33" tire means your pins are safe?
Old Jun 23, 2010 | 03:51 PM
CTNEDGE's Avatar
The tf's have 4 holes in the "storage" pin so you can use which ever one lines up in a manner where it won't be hit or knocked out at flex. I lost a pin during my first wheeling trip and figured out the different holes in the storage pin when it was replaced. Haven't lost one since.
Old Jun 23, 2010 | 06:31 PM
Super2's Avatar
Default Jks
I have the JKS Quicker Disconnects on my Jeep and I love them! I have the 0-2" disconnects, but the longer ones are the same and I don't see any reason why they wouldn't work well for anyone.
Old Jun 23, 2010 | 06:49 PM
Matador's Avatar
I have the Teraflex ones and I really like the design better...you just secure the whole swaybar....all the hardware is included.
I was wheeling on the weekend and someone just had the swaybar strapped up....it came loose and then started rubbing against the tire. They then had to use a hi lift jack to pull it back into place as it had shifted more to one side.
The Teraflex is a better design!
Old Jun 24, 2010 | 06:19 AM
The_Yeti's Avatar
This is another reason why i went with the TF disconnects.
Same thing went wheelin and tied up my front sway bar only to have it fall down and shift to the driver side a little.
Old Jun 24, 2010 | 06:34 AM
... someone just had the swaybar strapped up....it came loose and then started rubbing against the tire. ...
Originally Posted by Roeanoke
This is another reason why i went with the TF disconnects. ...
If one really wanted the JKS (or any other brand), they could always buy the TF storage pins and brackets separately:
Disco Storage Brackets
Old Jun 24, 2010 | 06:44 AM
... My guess, 4.5 BS with a sub-33" tire means your pins are safe?
Certainly could be. It's difficult to tell from a year-old thread what configuration everyone was running when they experienced a problem if they don't put it into the post (since signature lines update all across when the individual updates, and some of us update our profile as we add mod's). Anyway, it appears that OP in that thread was running 35"x12.5" tires on stock wheels--at least even today his profile doesn't indicate a wheel change. Certainly that would cut down on clearance and possibly lead to problems. In fact, there was a very old thread in which the TF QDs were ripping open tire sidewalls on stock wheels/oversized tires under extreme articulation. I personally don't recommend this combo for those who wheel hard (and I don't think TF does either).
Old Jul 1, 2010 | 02:44 PM
The_Yeti's Avatar
After some serious flex and grind this last weekend Stock Sahara rims and tiers will produce some major rub on the top bolt and sway bar/link Wheel spacers are the next on the list!
