Swaybar help.... Please..
Old Sep 18, 2011 | 10:05 AM
NeverStock's Avatar
Default Swaybar help.... Please..
I cannot get the lower part o the sway bar to come off....Am I doing something wrong? I am holding the inside with an open ended wrench and using socket on outside.... But I cannot get it to break loose... Inside nut is starting to strip.
Used wd 40 on it... Am I missing something??? It just won't break loose...
Old Sep 18, 2011 | 12:47 PM
remingtonJK's Avatar
Check the threads that are exposed. They could be damaged. A file and a little work and you can fix them.
Old Sep 18, 2011 | 12:59 PM
Deere_Jeep's Avatar
There just plain a PIA. Maybe put sone up pressure on the link like your stock jack? might help a little. Just a PIA I tell ya.
Old Sep 18, 2011 | 02:09 PM
tslewisz's Avatar
WD isn't a penetrating oil. Try AeroKroil or PB Blaster.
Old Sep 18, 2011 | 06:22 PM
NeverStock's Avatar
Thanks for the responses... Guess I just need a little more elbow grease!!!!
Old Sep 18, 2011 | 06:26 PM
armycop's Avatar
I had to use a big pair of vise grips with a lot of pressure to get a set off once. Just use penetrating oil not WD40 and crank away. Replace them with some TeraFlex QD when you get them off, much better.
Old Sep 20, 2011 | 08:13 PM
NeverStock's Avatar
That is why I am trying to get them off... Replacing them with some home made quick discos...
Going to stop by lowes for penetrating oil tomorrow...
Thanks!!!
Old Sep 20, 2011 | 10:20 PM
Delux2769's Avatar
I was having the same problem till I stuck my jack under my axle and raised and lowered it slowly. Eventually I found the sweet spot and the bolt slid right out.
Old Sep 21, 2011 | 01:15 AM
RedJK2's Avatar
What size open end wrench are you using?
Old Sep 21, 2011 | 02:54 AM
afdude87's Avatar
Agree with delux. Find the sweet spot with a Jack. When I put my lift on that's what it took. Front and rear. Kroil is good stuff though. Used it a LOT rebuilding old engines. Or as planman said cut it off.
