swaybar link droop limit?
Old Apr 19, 2009 | 09:49 AM
meatsandwich's Avatar
Default swaybar link droop limit?
Is anyone out there using the full extension of their swaybar links with the electric disco? As it is on my jeep right now, the front axle droop stop is the shock extention limit, and at full droop there is a slight bend at the link/ swaybar. I belive most 3" lifts do this. I have new longer shocks in the garage, but at full drop the swaybar links would be maxed out. The up travel is fine still showing shock piston.
1) Can the links travel "backwards" into the draglink once fully extended with the electric swaybar disco'd?
2) Would using the swaybar links as droop "limit straps" have any other drawbacks?
Thanks for any info you have!
Old Apr 19, 2009 | 11:52 PM
rickl's Avatar
do not have all the answers but here's what happened right after upgrading to longer travel shocks,left went to full droop,then steering got kinda tight,well picture kinda shows the rest
Old Apr 20, 2009 | 01:28 AM
YellowToy's Avatar
Rickl... I see you have the TF discos. Wheer both sides connected when you did this? Or didi you only disco the other side?
Old Apr 20, 2009 | 08:29 AM
rickl's Avatar
both sides were connected,was lazy and just using Rubi disconnect,when LHS went to full droop,allowed the rubi sway bar to go over center and go the wrong way when axel came back up,these sway bar kinks were too short for new shocks I had just installed
Old Apr 20, 2009 | 09:30 AM
Calypso's Avatar
I believe that should answer the original question!
Old Apr 22, 2009 | 04:26 PM
Thanks rickl!
