Switch Panel in Stock Location?
Old Apr 30, 2012 | 01:08 PM
jeepken's Avatar
Default Switch Panel in Stock Location?
Is there a switch panel that looks stock and replaces the stock switch panel? I want to add lights and do not want to add random switches in random places if there is something that uses the actual stock panel. Perhaps I can still use stock, but just add some stock looking switches? Is this something I could get reasonably priced from Mopar (tsk-tsk) or another vendor? I'm not seeing anything via search so I had to post.
Old Apr 30, 2012 | 01:15 PM
wayoflife's Avatar
JK-Forum Founder
to the best of my knowledge, there is nothing out there that replaces the stock switch panel.
Old Apr 30, 2012 | 01:20 PM
olram30's Avatar
get a daystar. https://www.jk-forum.com/forums/jk-e...-panel-223451/
Old Apr 30, 2012 | 01:27 PM
SiliconTi's Avatar
+1 on the Daystar - looks like it is supposed to be there.
Old Apr 30, 2012 | 01:40 PM
Mopar2Ya's Avatar
& more Daystar: https://www.jk-forum.com/forums/jk-s...2012-a-219572/
Old Apr 30, 2012 | 02:04 PM
jeepken's Avatar
The Daystar option looks pretty clean and I'm going to look into that a bit further.
Why is it after all these years, Mopar does allow us to use the additional buttons they included on the stock panel? Is there really a technical reason or is this just one of those things we all don't understand?
Old Apr 30, 2012 | 02:10 PM
blang816's Avatar
Since you have 2011 I'll show you what I did in my 2012. I like it because you can't see the switch, but when on the light glows inside, but not irritating.
As far as the sitch panel, there is nothing and you can't put a switch there because it all one circuit board behind it. Here is a picture of it taken apart. Don't do this because for somereason the hazard light button doesn't work and someone else has had the same issue.
Old Apr 30, 2012 | 02:54 PM
jeepken's Avatar
I really like that setup and am moving it to the top of my list. I guess I now understand the stock switch issue now that I see the pic of the circuit board. thanks!
