SYE kit
Old Apr 2, 2008 | 03:26 PM
TxCop07's Avatar
Vet Army
Default SYE kit
I have heard of people having drive shaft angle problems with a SL over 4". If you install an SYE kit you have to put in a longer driveshaft. It would then change the angle. My question is does a SYE kit solve the problem. I am wanting to get a 6" long arm SL.
Old Apr 2, 2008 | 04:31 PM
Piginajeep's Avatar
You dont need an SYE in a JK, it already has a fixed yoke..
thats a TJ YJ thing.
New Double cardin driveshafts will fix the issue
Old Apr 2, 2008 | 04:37 PM
wayoflife's Avatar
JK-Forum Founder
Exactly what piginajeep said - the JK's already have a fixed yoke and only need a double cardin u-joint style shaft to address this issue. Of course, if you have a 4-door, you don't really even need to do that especially if you have a 6-speed.
Old Apr 3, 2008 | 01:34 PM
TxCop07's Avatar
Vet Army
can you get the double cardin u-joint style shaft from quadratec?
Old Apr 3, 2008 | 01:49 PM
TxCop07's Avatar
Vet Army
is it just the rear that needs to be replaced?
Old Apr 3, 2008 | 02:55 PM
Piginajeep's Avatar
4 door or two door?
call Dave at Northridge4x4, He sells JE Reel, I'm not sure if q-tech does
Old Apr 3, 2008 | 03:21 PM
TxCop07's Avatar
Vet Army
i have a 2 door
Old Apr 3, 2008 | 08:42 PM
Piginajeep's Avatar
Originally Posted by SuperJeepJK
Yeah....but he is talking about 6 inches of lift. The front drive shaft will get vibrations, even with a Double Cardan joint. You just can't rotate the front pinion that high without killing your steering, unless you cut and rotate your axles.
I have six inches of lift and a 1310 double cardan drive shaft(4 door, Manual) and I still get some minor vibes.......but my steering is perfect. With the JK at 6 inches taller than factory, I feel that you can either deal with wearing u-joints slightly faster or wearing tires slightly faster.
why not opt for the spyntec kit from Solid, that'll solve your problems
Old Apr 3, 2008 | 08:44 PM
Piginajeep's Avatar
Originally Posted by TxCop07
i have a 2 door
, with a 2" lift you should'nt have any issues
Old Apr 3, 2008 | 08:51 PM
BajaJefe's Avatar
why not go with the dana 60s and some 40" tires!
