Synergy mount question
Old 03-17-2014, 07:01 PM
TaylarsJK's Avatar
Originally Posted by Dbird29
I had this same issue with the Synergy SS relocation bracket and tie rod clamp and ended up ordering bushings from Summit Racing for $5 each. Part #BSN-195447 I did have to grind them down a bit for length. Thought it was better to have the correct diameter bushing and couldn't get the OEM to drill out easily.
Sweet that's what I'll go with. Did you just use a press to remove and install the bushings?
Old 03-17-2014, 09:46 PM
courtsm3's Avatar
Ya my synergy SS didnt fit either. You're not alone on this one. Mine is mounted oem location until my relocation bracket is installed.
Old 03-18-2014, 05:19 AM
TaylarsJK's Avatar
Originally Posted by courtsm3
Ya my synergy SS didnt fit either. You're not alone on this one. Mine is mounted oem location until my relocation bracket is installed. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=538503"/>
Looks good with that synergy tie rod too, so you just ended up getting a new stabilizer instead of new sleeves in the OEM stabilizer?
Old 03-18-2014, 06:22 AM
courtsm3's Avatar
My bilstein 5100 ss was bent. When they were replacing my tie rod they discovered the bow in the shaft. Fox ss was all they had. Nice thick shaft and softer charge too. Jeep drives a little better. As for bolting it up, he just used the stock bolt on the axle side and the clamp side came with a bolt from synergy. but the axle side bolt from synergy wouldnt work i guess. Didnt ask why....
Old 03-18-2014, 07:48 PM
Dbird29's Avatar
Default An assortment of sockets and the vise did the job
I installed a synergy relocation kit too so i needed the 13mm bushings and each end of the stock SS. Used various deep well sockets and the bench vise change them.
Easy.
Old 03-19-2014, 06:40 AM
TaylarsJK's Avatar
I installed a synergy relocation kit too so i needed the 13mm bushings and each end of the stock SS. Used various deep well sockets and the bench vise change them. Easy.
I think I understand you process. So you basically used the vice like a ball joint press? Also did you replace the whole bushing or just the sleeve?
Old 03-25-2014, 01:37 PM
TaylarsJK's Avatar
Took the easy way out. Used 12mm bolts on each side of the stabilizer since my drill didn't have the power to drill the sleeves to 1/2". Although the bolts were a tiny bit loose inside the sleeves, when I tightened everything up everything seemed pretty damn tight and no rattles on the road. It's nice having a stabilizer on for the first time in a couple months..
Old 03-25-2014, 03:59 PM
TaylarsJK's Avatar
Some help on this would be nice, I get a great sounding pop when I steer completely each direction. I read that it could be the intermediate shaft that needs to be greased but just wanted to make sure.
Here's the link to the video:
http://youtu.be/tMwAte1md_I
Quick Reply: Synergy mount question
