Synthetic winch rope.
Originally Posted by FoxRacingJMC
I dont think a "rope cover" is what you'd be looking for, you just need your typical "winch cover" which will help prolong your rope.. I don't think there is just a "rope cover".
as said, if you have the money get a new one, yet you can fix this one by removing the damaged sections and rethreading and you conserve something like 80% of strength
just google for viking winch line fix or trail fix line, there are kits with the required tools but those are up to you
even if you replac it, try fixing it and keep the old one in yout jeep as an exnsion or backup
It has been suggested that using it until it breaks is a viable option, it isn't. There are possible situations such as winching up a steep hill, or winching in some extreme off camber situation that if your winch line breaks your vehicle and life (or that of others) could be needlessly endangered by following the "use it till it breaks" motto. This isn't some mechanical question involving failure where the result would be fixing what broke on the trail, this is an issue of safety which we should all hold in the up-most regard.
Moral is, buy a new rope. Use some of the money you saved by buying used and buy some new rope and adhesive remover for those God-awful stickers.
Good luck,
Tyler
Good luck,
Tyler
Good luck,
Tyler
Good luck,
Tyler
