t case
Ooooh....Atlas sweetness.....what? didnt wanna try the new 4? I am very interested to see how the install goes! Do you have a Rubicon or X or Sahara? You better plan on making an install write-up on this....
just came in to take a break and go swimming just an update got my bilstien shocks yesterday so there done, brake lines done, test drive offroad done, t case and driveshafts off went super easy pretty basic will take pics later, i will do a write up on what size wrenches,etc. but its really simple
actully none an easier method is just to install a 1 inch spacer and longer studs which i will have atlas send me tommorrow the input shaft is exactly 1 inch diff i believe the stock is 1 3/8 and atlas is 2 3/8 you could cut the atlas shaft down but thats alot of steel to cut and trim the output shaft flush with the t case adapter its to hot here to be messing with that so i will just bolt on the spacer since there are no clearance issues under the cab
