t case
Old Jun 1, 2007 | 08:21 PM
aetcmh's Avatar
Default t case
has anyone or knows anyone that has installed an atlas 2 in the jk yet just got mine today going to start in the morning looking for any tips
Old Jun 1, 2007 | 09:53 PM
Audiophiliac's Avatar
Ooooh....Atlas sweetness.....what? didnt wanna try the new 4? I am very interested to see how the install goes! Do you have a Rubicon or X or Sahara? You better plan on making an install write-up on this....
Old Jun 2, 2007 | 01:33 PM
aetcmh's Avatar
just came in to take a break and go swimming just an update got my bilstien shocks yesterday so there done, brake lines done, test drive offroad done, t case and driveshafts off went super easy pretty basic will take pics later, i will do a write up on what size wrenches,etc. but its really simple
Old Jun 2, 2007 | 01:50 PM
jk-rubicon's Avatar
I think that quadratec show truck put in an atlas. I watched the show "extreme 4X4" on Itunes
Old Jun 3, 2007 | 01:52 AM
2K1TJ's Avatar
Taking notes.
Old Jun 3, 2007 | 01:13 PM
marionnc's Avatar
bump for pics!
Old Jun 3, 2007 | 02:35 PM
aetcmh's Avatar
heres some pics of the atlas will be posting more on the write up when finished
heres the old NP241
Old Jun 3, 2007 | 02:47 PM
marionnc's Avatar
how much cutting is going to be required to seat the atlas?
Old Jun 3, 2007 | 03:15 PM
aetcmh's Avatar
actully none an easier method is just to install a 1 inch spacer and longer studs which i will have atlas send me tommorrow the input shaft is exactly 1 inch diff i believe the stock is 1 3/8 and atlas is 2 3/8 you could cut the atlas shaft down but thats alot of steel to cut and trim the output shaft flush with the t case adapter its to hot here to be messing with that so i will just bolt on the spacer since there are no clearance issues under the cab
Old Jun 3, 2007 | 03:18 PM
marionnc's Avatar
will you have to cut the sheet metal in order to get the shifters into the cab?
