t case blew up
Old May 16, 2012 | 12:59 PM
greenmonster516's Avatar
Default t case blew up
sooo im driving down the interstate and i start to hear a noise but ive got my doors off and everthing so when i heard it it was too late and all of a sudden i hear a horrible noise and i pull over and look and the bottom of my trasfercase is gon and my front drive shaft is sitting on my t case skid and you could seee straight up in to the t case.. its sitting at my cousins lot and im going to pick it up with my car trailer tomorrow.. but what do i do? where do i k\take it? is my ring and pinion on the front going to be shredded? and i want to know abt the atlas t case.. thanks.
Old May 16, 2012 | 01:05 PM
damon.l's Avatar
punctuation and proper english. they make your post more readable.
Old May 16, 2012 | 01:07 PM
ronjenx's Avatar
First, lets see if we can determine what caused it.
How many of these things apply to your Jeep?
Lifted
Aftermarket front drive shaft with a double cardan at the t-case
Adapter at the front of the t-case that places the double cardan farther away from the t-case
Angle of front pinion and the drive shaft greater than a few degrees
Re-geared
Traveling at or above highway speed
Old May 16, 2012 | 01:13 PM
4" of lift
double cardian driveshaft in the front and back but the back isnt a problem
going about 80
35" tires
i think 5:13 gears
6 speed
Old May 16, 2012 | 01:15 PM
teh215's Avatar
Lifted
Re-geared
Would anything related to the front driveline matter if he was not in four wheel drive? OP was not in the highway in 4wd, correct?
Old May 16, 2012 | 01:16 PM
ronjenx's Avatar
The front driveline spins in 2wd, too.
Most of the t-case explosions were on the highway in 2wd.
no i was not in 4wd.... im sure of it.
Old May 16, 2012 | 01:20 PM
ronjenx's Avatar
Originally Posted by greenmonster516
4" of lift
going about 80
35" tires
i think 5:13 gears
6 speed
That is pretty much the recipe for disaster.
How was your front pinion aligned with the drive shaft?
A double cardan at the t-case requires the single at the front to have no more than a very few degrees of misalignment between drive shaft and pinion.
Another factor is maintenance. How often have the u-joints been greased.
Old May 16, 2012 | 01:24 PM
i have heard my driveshaft was at a pretty good angle. it didnt seem miss aligned, and they were greased less than 2 months ago.
Old May 16, 2012 | 01:27 PM
ronjenx's Avatar
That could just be someone saying "Yeah, that'll be fine". And, some people get away with it. It's all the things that add up that can cause the drive shaft to vibrate to a critical point.
