t case blew up
Conversely, trying to maintain a good pinion/drive angle, would cause a bad caster angle.
Very true Ron. My comment was more generic- bad caster angles on JK housings are the cause of many failures. While trying to maintain decent steering manners, these poor angles lead to improper DS angles.
I didn't make that connection from your post.
33
That is pretty much the recipe for disaster.
How was your front pinion aligned with the drive shaft?
A double cardan at the t-case requires the single at the front to have no more than a very few degrees of misalignment between drive shaft and pinion.
Another factor is maintenance. How often have the u-joints been greased.
So where exactly do I grease the U Joints & will that be able to be done on both front & rear plus what will I require to do this ?
Also what about the rubber boots. Do they require some maintanence ?
What should be the OK angles for alignment.
Still learning all this stuff as you can tell.
Oh buy the way Ron I'm off to Duxford again this year for 'Flying Legends'
What did you want me to look for in that Concord again ?
Didn't get a chance last time. Too many Spitfires & Mustangs to watch
Thanks
Did you see this article? Project-JK.com - Jeep JK Wrangler Resource » Jeep JK & Caster: What is it? How do I measure it and how does it affect my Jeep?
JK caster isn't great from the factory at just over 4*. When a JK is lifted, even just a little, the DS angle can be adversely affected. With a 4" lift, the DS angle must be corrected. To correct the DS angle you're taking away caster. 2* of cater is marginal but it's pretty common when you see a corrected DS angle.
Had my JK 3 years now still stock with an AEV 2.5" lift going on this year.
Thanks
Thanks
The stock cv joints would have to be disassembled to properly lube them.
I envy you the Duxford trip. I really enjoy that stuff.
Look for a MAINEiac sticker on the side of the Concord. It was put there back in the '80s when it came through Bangor, Maine.
(I'll post a pic of a sticker as soon as I find one on my computer.)
