Tailgate Table Install
I am looking to add a tailgate table. I'm leaning toward the Trailgator Table, since it's a no-drill, JK-specific application. But this table, and other similar tables, cover most of the vent in the tailgate. My question is...is covering the vents like that a problem? I know that the vents are maily for the pressure when you're closing your doors. But does it also allow venting when you're running with the Freedom panels out. I thought I read once where someone blew out their rear window, because they had covered the rear vents and then ran with the Freedome panels out at high speed, but I can't seem to find it now, so my memory might not be right.
Those vents help cool your jeep interior.
In hot summer, run the a/c. You will feel it blowing the hot air out the tailgate vent.
After about 10~15 min switch to recirculate for the best cooling efficiencies, I've found.
