Tailgate Table Install
Old Feb 13, 2012 | 09:01 AM
jckid's Avatar
Default Tailgate Table Install
I am looking to add a tailgate table. I'm leaning toward the Trailgator Table, since it's a no-drill, JK-specific application. But this table, and other similar tables, cover most of the vent in the tailgate. My question is...is covering the vents like that a problem? I know that the vents are maily for the pressure when you're closing your doors. But does it also allow venting when you're running with the Freedom panels out. I thought I read once where someone blew out their rear window, because they had covered the rear vents and then ran with the Freedome panels out at high speed, but I can't seem to find it now, so my memory might not be right.
Old Feb 13, 2012 | 03:26 PM
jckid's Avatar
I know quite a few people on here have tailgate tables and other things covering part of their tailgate vents. No one has any thoughts or opinions on this?
Old Mar 11, 2012 | 04:32 PM
HIROLLR's Avatar
Where did you find the Trailgator table? I googled it but nada?
Old Mar 11, 2012 | 05:15 PM
Tiburon's Avatar
Try this:
hxxp://outbackadventureproducts.com/author/Doug/
Old Mar 11, 2012 | 07:55 PM
deeker's Avatar
Make your own, or look at the Vector Offroad table. It doesn't have a back panel, just side supports for the tray.
Old Mar 11, 2012 | 08:04 PM
CerOf's Avatar
Those vents help cool your jeep interior.
In hot summer, run the a/c. You will feel it blowing the hot air out the tailgate vent.
After about 10~15 min switch to recirculate for the best cooling efficiencies, I've found.
