Tcs light flashing
I have lifted my 08 2 door rubicon 3.5" and put 295/70/17 trail grapplers on...aligned it all works great except while going around cloverleaf exits...sweeping right or left turns cause Tcs light to appear and a metal on metal grinding sound to occur like really worn pads...tried to turn off Tcs system according to pg 114 in owners manual...can't get it to stay off though...any thoughts? Some help would be much appreciated
Make sure your realign the steering wheel after lift. That should get rid of Jeep sensor issues. If you are rubbing tires, you may need spacers if you put on larger (wider) tires without new rims with less backspace.
