Tera 2.5 coil plus spacer
Old Jan 15, 2012 | 03:16 PM
NCRUBI2012's Avatar
Default Tera 2.5 coil plus spacer
On Monday my TF kit will arrive. I had already bought Daystar 3/4 front space to remove rake but decided to just do the lift instead. Should I or could I add the Daystar space to the TF lift? I assume I will still have the rake if I do not? After bumper and winch I am sagging 1" on the front. 2012 2 door rubi if that makes a difference. TIA
Old Jan 15, 2012 | 04:15 PM
Vin's Avatar
Vin
You are sagging after the lift? I have Mopar steel bumpers front and rear and a Warn 9.5ti winch. My Jeep sits level with just the lift.
Old Jan 15, 2012 | 06:45 PM
RLW007's Avatar
I have a 2011 unlimited Rubicon with 2 1/2" TF lift. I needed the 1" spacer to make it level. Still sits pretty level with winch and LOD midwidth front and rear bumpers.
Name:	jeep rubicon 001.jpg
Old Jan 15, 2012 | 06:58 PM
NCRUBI2012's Avatar
I have not installed lift yet. Daystar was purchased to level until I decided on the lift. I scrapped the idea and just went for the lift....that is not here yet. My question is can i use the Daystar I have with the TF w/o any issues? Thanks.
Old Jan 15, 2012 | 07:34 PM
Vin's Avatar
Vin
As far as I've seen on the various boards, yes, you can stack leveling disks with coil springs from lift kits. You shouldn't have a problem with 3/4 inch pucks. Just make sure none of the brake or sensor lines are overly stretched.
Old Jan 16, 2012 | 09:56 AM
jason0341's Avatar
I run a 2.5 TF coil lift along with 1" TF spacers all around. Helps with weight of front and rear bumpers.
Old Jan 16, 2012 | 10:16 AM
whiterhin0's Avatar
I also have 2.5" tf coils with 1" spacers up front. Looks and rides great
