Teraflex 1.5" PErformance Level Install Question
Old Jul 27, 2011 | 10:36 AM
OzzyPotter's Avatar
Default Teraflex 1.5" PErformance Level Install Question
Read the searched topics on this but never got a clear opinion.
Has anyone installed this kit without removing control arms? I figured it should be relatively simple but the teraflex directions require quite a bit of removal. Necessary? Anyone want to share how you did this?
Thanks for any input.
Old Jul 27, 2011 | 10:51 AM
greenenvey's Avatar
is your the coil or puck kit? i have the puck and didnt have to remove control arms?
Old Jul 27, 2011 | 11:01 AM
mattgt5's Avatar
You should at a minimum loosen them and then torque them back when finished. You don't want to put any undue tension on them or "bind" them
Old Jul 27, 2011 | 11:08 AM
TeraFlex's Avatar
Sponsoring Manufacturer
You do not need to remove the control arms. You only need to loosen the control arm bolts so the bushings do not bind up.
Old Jul 27, 2011 | 11:16 AM
dxfiles's Avatar
Make sure you loosen but do not remove. After all is done and back on the ground then you tighten it all back up.
It is pretty straight forward...My buddy and I had never done a lift before and it took us about 4 hours.
I actually used some of the write ups to Enhance the instructions from Teraflex.
I love the Kit---
http://www.youtube.com/watch?v=-1b4RUJ0tXA
Old Jul 27, 2011 | 03:14 PM
OzzyPotter's Avatar
Thanks for the info. I guess the Teraflex instructions are right. Gonna do this next week so wanted to check and see if all was necessary,
Old Jul 27, 2011 | 04:16 PM
GeoJeep33's Avatar
I made the mistake of tightening up my front track bar before setting it down. Next morning I noticed the front axle was about 1/2" or so to the driver side. Loosened everything up, shook it, torqued it all up...all was well.
