Teraflex 2.5 or 3 in?
Old Feb 7, 2013 | 08:25 AM
chad s's Avatar
Default Teraflex 2.5 or 3 in?
What's the major difference between the 2 besides 1/2 inch? Don't want to do any mods to the driveline thanks
Old Feb 7, 2013 | 09:19 AM
emiles1987's Avatar
2.5 is the sweet spot - above that you're looking at upgrading control arms, trackbars, possibly driveshafts...
Old Feb 7, 2013 | 10:19 AM
SpicedCrusher's Avatar
Agree on the 2.5 but your going to want a front adjustable trackbar. There is a relocation bracket for the rear so not needed. LCA's are nice and make the ride better, not necessary but I'd recommend them.
Old Feb 7, 2013 | 05:35 PM
PF20's Avatar
And it's like a 300+ difference for that half inch. I'll eventually get the 2.5 myself.
Old Feb 7, 2013 | 05:37 PM
1995nscajeep's Avatar
3 your getting on touchy ground w drive shafts and such I got the 2.5 tf coil lift performs good rides good and clears my 35s just fine
Old Feb 7, 2013 | 06:04 PM
tabber02's Avatar
even with a 2.5" lift, if you do a lot of flexing you're going to wear your DS out... if you're already on the fence about a 3" lift, get the lift. as it's been said - get a front adjustable track bar. the TF monster forged track bar is a good addition to their kit.
added to legit control arms... my 0.02.
Old Feb 7, 2013 | 07:21 PM
emiles1987's Avatar
I've got about 5" of lift and do wheel it regularly. The factory drive shafts haven't let me down yet (4Dr). I do have a Coast front in my shop for back up, but after a year still running strong...
Old Feb 7, 2013 | 07:27 PM
jkjurny's Avatar
I was also torn. If you want to be on the lower side for looks or stance, go 2.5. I went with the long arm lcg elite 3". It came out taller than I expected with front and rear bumpers. Teraflex does run high in their lifts.
If you want it high, go 3", but as everyone said , you'll need more parts. Non matter the lift, if you will be wheeling and flexing, get a new Drive shaft. It'll avoid you putting in exhaust spacers. The spacers end up conflicting with different after market skids.
