Teraflex 2.5" BB Lift Question
Old Sep 15, 2007 | 08:27 AM
Uticon's Avatar
Question Teraflex 2.5" BB Lift Question
I just installed my lift with the spring spacers and shock extensions.
There were a set of sway bar links with the parts that are about 2 inches longer than the stock rear sway bar links.
Should i take the stock REAR sway bar links and install them on the front and put the aftermarket longer ones in the rear?
I bought the kit used with no instructions, and the only installation instuctions i could find online didnt have anything about moving the sway bar links.
Old Sep 15, 2007 | 08:31 AM
JB Motorsports's Avatar
The longer ones you received from Teraflex should replace the stock rears. The stock rears then replace the front sway bar links...as you said.
Here is a write up from Wayolife that might help, I'm not sure if it mentions the sway bar links either though...???
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Sep 15, 2007 | 11:06 AM
Uticon's Avatar
Thanks for the help.
I thought i was right but the Jeep rides fine with the stock links.
Next time i m into a little project ill swap them out.
Old Sep 15, 2007 | 12:59 PM
FuLcRuM's Avatar
They are mainly for the Rubicons, the fronts tend to "flip" the wrong way when you are disconnected offroad. If you don't have a rubi it's not as important since you actually remove the links to disconnect.
That being said I did replace my rears with the longer ones since I thought they put to much stress on the rear swaybar mounts (frame) and were possibly restricting flex slightly.
Old Sep 16, 2007 | 07:55 AM
Uticon's Avatar
I do have a Rubicon and i found out the front sway bar POPS into the disconnect mode since i didnt swap out the sway bar links.
That little note should be added to the write up.
Alls good now.
