teraflex 2.5 bb and stock tires
#21
#22
I have the rear trackbar bracket and when I initially had the rear links on the outside, there was no way to botl the rear driver's wheel on. When I moved them to the inside, I could bolt it on but the tire rubbed the sway bar when I put the lugs on. When they are mounted on the inside, I could trun the tire by hand. On the outside, the tire was basically unmountable on the hub.
It seems to reason that many Jeeps are set up differently so it is hard to say who will have issues. But keep in mind that you can fix (somehow, someway) what ever you run into with this lift.
My problems are over as I have new tires and wheels with 4.5 BackSpacing.
