Teraflex 2.5 Lift Advice
I have a 2012 JKU Sport currently with 33's and 4.5 BS. I've searched on here and can't find find an answer to this. If I buy the TF 2.5 lift without shocks or adapters, other than shocks obviously is there any other parts I would need to buy right away? i.e. Trackbar, LCA, UCA, Discos, etc. ??? Thanks in advance guys!
You'll be fine with the budget boost kit. Track bar & CA's not really needed until you're 3"+ or if you wheel it hard. If you're planning on running trails, you may as well get disconnects.
It will be about 80% DD and 20% Off Road. I'm looking at the 2.5 coil lift and adding bilstein 5100s. I didn't know if I'd need to get and adjustable TB or LCA's right away.
I have the 2.5" in kit and I do have the shocks also but it came with a rear track bar relocation bracket and new rear sway bar links and you move the back ones to the front but I already had jks quick discos up front so I didn't resuse the old ones... I'd love to trade you lifts !!
Full-Traction Suspension Jeep JK Wrangler 3.0" "Economy" Lift System for Jeep JK Wrangler 4-Door Model
I'm looking at this one also. For another $100 bucks you can add an adjustable TB and what appears to be SB discos? Just haven't heard much about FT like I have TF.....
Sponsoring Manufacturer
