Teraflex 3" and 37's
With the 3" Teraflex lift on my 2 door, I am currently running 35's with what looks like a lot of room to go bigger. Anyone with input on 37's and the 3" Teraflex set up. I know I got more than 3 with the 2 door.
you can do it but you will need to do some trimming of the body and chopping of your fenders. you will also need to install taller bumpstop extensions. i know it looks like you have enough room to clear 37's but you will rub at a flex if you leave things as is.
almost the same, I have a 2.5" TF coil lift with 1" spacer front and 1 3/4" spacer rear and can fit 37's. I had to trim the pinch seam/rock rails a fair bit, but other than that there doesn't seem to be any rubbing issues.
i am just wondering what is the need for taller bumpstops?
