Teraflex 3" install problem!!!
Old May 19, 2008 | 06:38 PM
cibach's Avatar
Originally Posted by whpony96
Before you mount it check the stock welds around the factory bracket on the axle itself. If the paint is popped off the welds the weld is cracked and you will need to have them re-welded prior to you putting on the new bracket. This is why they made the new bracket.
The new Rear Track Bracket will be shipped to you free if you have purchased a 3" Lift from them in the past and did not receive the newly designed bracket with your kit.
huh, I don't understand
Old May 19, 2008 | 06:46 PM
BlackRubi's Avatar
Does that mean you use this new bracket and remove the old bracket from the passenger side?
Old May 19, 2008 | 06:47 PM
whpony96's Avatar
Did you put the lift on already without the new bracket?
Old May 19, 2008 | 06:48 PM
whpony96's Avatar
YES once you have the new Rear Track Bracket you no longer need the shock relocation mount for the passenger side.
Old May 19, 2008 | 06:53 PM
cibach's Avatar
I have the old bracket installed right now.. I am waiting on the new bracket to be delivered
Old May 19, 2008 | 06:54 PM
Renegade's Avatar
Yes, I was told to throw the old frame mounted bracket away. I am putting on my new one tomorrow.
Old May 19, 2008 | 07:07 PM
whpony96's Avatar
Yes then DEFINITELY check the welds on the factory bracket to see if any of the paint has popped off of them. This is a positive sign the weld is cracked and weak.
If the paint is still intact your good to go!
Oh and mount the track bar to the top hole of the bracket (there are 3). As in the picture I posted above.
Old May 19, 2008 | 07:12 PM
BlackRubi's Avatar
Thanks Renegade. Do you know if I can purchase one from Teraflex directly?
Old May 19, 2008 | 07:21 PM
whpony96's Avatar
If you call Teraflex they will ship you one free! IF you purchased the 3" kit.
Old May 19, 2008 | 07:26 PM
Renegade's Avatar
Like whpony96 said, they will send you one if you have the 3" kit. If you just want to buy one, you will have to get it from one of their distributors. The part number is posted in the billboard area on here, if it wasn't already posted in this thread.
