Teraflex BB add-on advise needed
Old Feb 15, 2008 | 06:38 AM
The Joker's Avatar
Default Teraflex BB add-on advise needed
Ok, so I'm FINALLY ordering my Teraflex 2.5 BB with shock extenders tomorrow. putting on 33's with 17"pro comps.
Any suggestions of add on's that I should get with it? discos other stuff?
thanks!
Old Feb 15, 2008 | 07:56 AM
BaltChief's Avatar
The new kits come with a rear location bracket, but you might want to consider a front adjustable trac bar to center your front axle.
Old Feb 15, 2008 | 09:13 AM
theosdad's Avatar
Does this bar correct for any rubbing with the stock rims and tires on a 2008 X Unlimitted? Cant we also use our rear traction bar upfront like wayolife says on his write-up?
Old Feb 15, 2008 | 09:28 AM
150's Avatar
150
Fallen Hero
No but some new AEV PINTLERS will.
Old Feb 15, 2008 | 09:29 AM
The Joker's Avatar
thanks balt. any other suggestions?
Old Feb 15, 2008 | 09:40 AM
Sparky99's Avatar
I'm ordering the same lift here pretty soon and going to get the Teraflex discos and their half inch spacer for the front to take out the factory rake.
Old Feb 15, 2008 | 09:42 AM
theosdad's Avatar
I was under the impression that the new relocation bracket fixed any rubbin issues. I guess I was wrong.
Old Feb 15, 2008 | 09:52 AM
The Joker's Avatar
where did you order from? do you have a part number for the 1/2" pucks?
Old Feb 15, 2008 | 09:53 AM
I have the bracket installed and it does run the driver's side at full droop.
Old Feb 15, 2008 | 09:58 AM
theosdad's Avatar
If it still rubs then what was the reason behind this new bracket?
