Teraflex BB add-on advise needed
the issue with rubbing is not the track bar. its the SWAY bar links. i think you were just referring to the wrong part. the track bar relocation bracket is used to recenter your axle and the jeep. i would recommend a new track bar for the front as well. u may want to pay an extra $100.00 for the discos and $15 for the extended rear sway bar links. they both have zerk fitting for easy greasing.
so let me get this correct... the Teraflex 2.5" BB doesnt come with the extended rear swap bar bracket?
So I'll need to opt for this option, I also am looking at the JKS Disco's.
QUOTED from Teraflex's site...
The trackbar bracket is required on lifts of 4"or more. The trackbar bracket helps to restore the trackbar to a natural position to keep the rear axle correctly centered under the vehicle. The trackbar bracket is designed to keep the trackbar functioning properly with no binding or other interference with other components.
i saw the post in the vendors section now for the 2.5" BB bracket... so nevermind.
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/teraflex-rear-trackbar-bracket-2-5-bb-28985/
