teraflex install question
Old May 15, 2008 | 06:15 PM
cibach's Avatar
Default teraflex install question
I received my Tera 3" kit today... I see most people have move the rear sway bar link to the front(on the Rubi) my lift came with front disco's on the front.. should I install them or just move the rear to the front?
Also the springs are gold colored?? Is that right?
Any gotchas on the lift. I also got the new HD front trackbar..
Old May 15, 2008 | 06:43 PM
id use the sway bar links they gave you. and yes the springs are supposed to be gold colored. how is that hd trackbar btw?
Old May 15, 2008 | 06:50 PM
cibach's Avatar
I must say the HD trackbar is extremely heavy duty... it is a beast..
Old May 15, 2008 | 08:58 PM
tburk49760's Avatar
on my rubiwagon i had to get longer front links cause they would overcenter at full flex and bend around the tie rod... teraflex was very helpful... i tried the rears up front and the longer ones they sent in the kit to no avail... full flexno problem now... if you dont max out the articulation the ones in the kit will be fine...
Old May 16, 2008 | 05:05 AM
zerodown's Avatar
I used the discos that came with the kit. They are fine. I pretty much keep it disco'd anyway.
