teraflex leveling kit?
Old Nov 23, 2011 | 01:41 PM
jasonr01's Avatar
Default teraflex leveling kit?
Looking to purchase a teraflex leveling kit, wanting to know if i will need to run wheel spacers with my factory tires on '11 unlimited sport s? running rubicon springs and shocks.
Just seen on nortridge 4x4 site,might need spacers
Old Nov 23, 2011 | 04:15 PM
coltc2000's Avatar
With factory sized tires no spacers needed. They talk about spacers because they are running a MUCH wider and taller tire on that JEEP. (34/13.5/18)
Old Nov 23, 2011 | 04:50 PM
OH9JK's Avatar
JK-Forum Ambassador
From the TF website:
Details
This leveling kit adds 2" to the front and 1" to the rear effectively leveling the 2 or 4 door's factory rake stance. The kit comes with front sway bar links. You can run a 33-34" tall tire with this kit. If you prefer to run the factory wheels as shown on the red Unlimited, you may need wheel spacers for proper clearance. Fits 2007+ newer Wrangler and Unlimited models
Old Nov 23, 2011 | 08:00 PM
CerOf's Avatar
I currently have this lift and it works well. Somehow the zerks keep coming off sway bar links which is VERY annoying.
You will be fine with stock tires and rims.
You WILL rub offroad with this kit if you disconnect with a 33" or 34" tire, even with properly spaced rims. You must increase bumpstops to keep from rubbing, trim your fenders or go aftermarket flat fenders.
I find teraflex's add misleading, they should revise their comments on fitment.
305/65R17 pictured below on my rig. Even with the rub, I like it. I'll trim one day.
Old Nov 23, 2011 | 08:34 PM
jasonr01's Avatar
Thanks for all the info. I plan on running stock for now so should be good til I spring for new tires.
Old Dec 10, 2011 | 06:20 PM
jasonr01's Avatar
Alright father in law wants my Oem tires off my jeep for his f150 so looking to buy new tires want to get 285/70 r17 don't wanna run wheel spacers, should I need to? Not going to disconnect the sway bar more then likely.
Old Dec 10, 2011 | 06:27 PM
trippnk's Avatar
Wheel spacers will also allow full turning radius. If you put on bigger meats you will more than likely rub at full lock. That part has nothing to do with disconnecting your swaybar ?
Old Dec 10, 2011 | 09:55 PM
Unforgivable's Avatar
2.5" teraflex, TF 9550 shocks, 34" BFGs on 18" stock sahara wheels. 1.5" spidertrax wheel spacers - even with them installed the wheel is still within the fender = legal. No rub so far, have not gone wheeling since install though.
Its not a necessity either, but you add bigger wheels on it you will notice a decrease in power and you speedometer off a little bit (5mph). It doesn't bother me too much but I'll be getting 4.88s the beginning of next year. Unless you got a rubi, than it shouldn't be too bad.
Old Dec 11, 2011 | 02:01 AM
Kojack's Avatar
i have the setup your talking about. i am running cooper st maxx tires. no rub only at full lock on flexed front suspension angles. its great. stock wheels, and leveling kit.
highly recommended.
Old Dec 11, 2011 | 05:20 AM
CJ7nvrstk's Avatar
Vet Army
Attachment 240910
Attachment 240911
Thanks for this info.
