Teraflex Prerunner - opinions
Anyone has Teraflex Prerunner kit with fox shocks on?
I'm considering this kit but I need opinions becasue it's quite expensive thing and I'd like to hear from others how it works.
I need it for daily driving on bad roads and sometins more serious offroading.
Check my build out, I'm doing a 4" PreRunner with ELKA's and 37's. https://www.jk-forum.com/forums/show...nlimited-Build
The prerunner is definitely something I'm impressed by (from just watching the videos), I am mostly out in the dunes which require high speeds, and I was kind of wondering how the dozer one posted above worked as well. On the site it says a 3" but the sponsor is saying 4" so I'm wondering if this is a different kit. Also, on the site it lists about 4k pounds for best results, but the 4 doors are a bit above that (4500 with all my stuff and me in it), so is there an unlimited version coming soon with a higher lift (by 1" or so that retains the scale of the 2dr with 3"), and higher weight rating?
Sorry to hijack this thread, just wondering.
Street, way, way better than stock. Better than the RK arms and 2.5 inch lift I had with Bilstien remote reservoirs.
Fast on forest roads, wash board, rally style driving. Holy crap this rocks!
Fast as the 3.8 can push me over whoops, soft silt, rutted, trails in the desert with big rises and drops. Awesome! I can haul ass and the only problem now is I don't have the power to use the suspension to it's limit.
Rocks, logs, and slow technical stuff. No difference from my old set up except it seem to articulate more smoothly and does not bottom due to the speed bumps.
It wasn't cheap, and I put about 25 to 30 hours into installing it (also took care of some other issues). But it was worth it.
I only had to call Teraflex once, and it only because I couldn't find a video I needed for the install. Great instructions, but make sure you watch them all, and look closely at their site because they have some newer versions out.
You can do much better then that kit for that money. It has poor rear geometry with the short upper arms (cycle the suspension and watch the pinion angle change) The teraflex speed bumps are a joke. Its a piece of foam in a shinny can but they use some fancy words to describe it. For what you are going to spend on that you could go with a full king coil over set up with real hydraulic /air bumps. At least you would have a system you can actually tune and adjust.
