Teraflex, RE, or Clayton??
I am down to the final debate for my automatic unlimited Rubicon. I am going to be running 37's and this will be my daily driver. What is everyone's opinion to which lift is best and why? If you have pics that would be great also. Thanks for everyones help.
I had an RE kit on my old TJ. It was okay. Personally, I'd narrow it down to Clayton and Teraflex and then do a by point comparison. Decide what's most important and weigh those and see who comes up on top.
I chose Clayton.
I chose Clayton.
RE kit you will have to go for the long arm kit to fit 37's, as for the other's im not sure I run the 3.5 RE superflex kit with 35's and next time ill be running 37's i no they will rub as the 35's already do so ill be adding a 2inch BL when that time comes down the road
If I were to do it all over again I'd drop the extra nickle on the Clayton kit. Both Clayton and Currie come in 4.5" flavors and neither feel long arms are necessary - I called both and asked when I was looking.
I am running a RE superflex short arm with 4.5 suspension and a 1 inch BL. I have no rubbing at all with 37's. I have swapped out the shocks on my RE kit to maximize the travel between full compression and full droop. I am running their front long arm shocks (11.25 inches travel) with 2 inch bump stops and another manufacturer from SLO, ca for the rear shocks to give 11.25 inches of travel w/ 2 inch bump stops. The thing is flexing out nearly perfect for a 4.5 suspension lift on 37's, meaning I am using the full shock on compression and droop.
If I did it over I would probably by it piece meal and build it mixing the best from each manufacturer.
