Which Teraflex shock?
Old Mar 6, 2011 | 11:33 AM
Mikelkey's Avatar
Default Which Teraflex shock?
Hey guys,
I installed the Teraflex 2.5 coil kit with shock adapters 2 months ago and now am looking to install Teraflex VSS shocks. I ended up with 3.5" lift in the front and 3" in the back. I do plan on installing .5" spacers in the back.
Quick newbie question. Do I go with the 2.5" shock (what comes with kit?) or go ahead and get the 3-4" shock.
Does it matter at all if I do not plan on rock crawling, etc.
Old Mar 6, 2011 | 11:39 AM
nthinuf's Avatar
Longer shocks means more axle droop. More axle droop means longer brake lines and more severe driveshaft angles. It could also mean coils falling out of the perches and over-compression on uptravel.
As long as you address all of the issues for downtravel, and use enough bumpstop that you are not over-compressing, longer shocks can work.
Old Mar 6, 2011 | 11:42 AM
Mikelkey's Avatar
Thanks for the quick reply. I will take it then that I should just go with the 2.5" since I wont be doing anything to crazy.
Old Mar 6, 2011 | 11:48 AM
Sn0w kr4wl3r's Avatar
Originally Posted by Mikelkey
Hey guys,
How did you get a 3.5" lift up front with a 2.5 inch lift kit? Are you 2dr or 4?
Old Mar 6, 2011 | 11:51 AM
Mikelkey's Avatar
Yes, it is a 2 dr. with the older T-flex 4 dr. kit. Brings up another question. Could my X shocks be causing the cupping I am getting on the edge of my tires?
Old Mar 6, 2011 | 11:53 AM
wazooz2424's Avatar
yes, you need the 2.5" shocks.
Old Mar 6, 2011 | 01:15 PM
Mikelkey's Avatar
Thanks wazooz for the confidence builder. I'd rather get it right this time.
Old Mar 6, 2011 | 01:18 PM
wazooz2424's Avatar
no problem. i went back and forth with Joe about this when I was deciding on whether to get a new lift or upgrade my TF 2.5".
Old Mar 6, 2011 | 01:22 PM
wazooz2424's Avatar
also, bad shocks or other suspension related components can cause cupping.
Old Mar 6, 2011 | 04:53 PM
Cpt. Flapjack's Avatar
If you want articulation, the ones you want end with the last 3 numbers 200. They are the ones from the older 2.5 kits that are now labeled for the 3"-4" kits. Just make sure you check you're ABS and Brake lines at full flex.
Go to their web site and download their catalog. There is a a section that shows the actual shock dimensions.
