Teraflex Steering Stabilizer Install Question
Per WOL's instructions I installed the Teraflex HD steering stabilizer this past weekend. I had to adjust the bracket on the axle mount in order to keep the stabilizer from hitting the trackbar axle mount when turning the wheels to the passenger side. Has anyone else ran into this issue? It works fine now but the stabilizer hangs lower than the stock stabilizer.
Do I need a relocation bracket for this?
That's what I did. I just don't like having the stabilizer and the mount hanging that low to the ground. It hangs about as low as the differential now.
It's partially blocked in this pic but I think any noticeable bend would be seen. Does anyone have a picture of this stock with an unbent tie rod?
So are you saying that the tie rod is bent upward? If it is bent inward towards the back of the jeep or outward towards the front I don't see how that would affect the clearance of the stabilizer unless it used to be an inch closer towards the front in which case it doesn't appear to be that far bent
it looks bent upward to me and it looks just like mine, and i just ordered the rockrawler hd tie-rod with moog ends for $ 179, but the moog ends dont come with the tie-rod they have to be purchased at your local auto parts for around $60 - $80 ea. and had to remove my SS relocation bracket....
though i think the bracket did'nt work with the hd rockrawler drag link....
So should I get a new tie rod or get a steering stabilizer relocation bracket? Or would it be a bad idea to do both? Would the Woods relocation bracket work with the Rockcrawler one?
How will driving on my slightly bent tierod adversely affect my Jeep?
hey WOL what setup do you have with your SS? are you running a reloc. bracket or a double SS... ? oh, and by the way i have been running with a bent tie rod for quite some time and my front tires were wearing unevenly like WOL said so get on top of the tie rod and get the bent one out....
the tie rod is responsible for toe right?
once i install the new one i just measure it to the same length as the old one and are you or any one running anything specific as far as the toe adjustment or is it just left stock i have 4" lift with 33" bfg mt's and was just wondering if there are any benefits to changing the toe settings? thanx WOL, got your pm (oops) case closed...lol
