Teraflex Steering Stabilizer Install Question
). i just recently got a new TF SS and i'm just running it right now.
oh, and by the way i have been running with a bent tie rod for quite some time and my front tires were wearing unevenly like WOL said so get on top of the tie rod and get the bent one out....
the tie rod is responsible for toe right?
once i install the new one i just measure it to the same length as the old one and are you or any one running anything specific as far as the toe adjustment or is it just left stock i have 4" lift with 33" bfg mt's and was just wondering if there are any benefits to changing the toe settings?
I really dont think your tie rod is bent, I had the same problem with the teraflex SS. You have to remember that the tube for the teraflex ss is bigger than the stock one hince the clearance issue. As for some other people not having problems im guessing that all the brackets that are mounted to the tie rod are not rotated to exactly the same position on every Jeep, so some might clear without having to rotate it down. If you are really concerned about the tie rod being bent I wouild take it off and roll it accross some 2X4s evenly spaced and see if there is any woble, kinda like checking a cue on a pool table. Thats what I would do unless you have the extra cash just to upgrade anyway. Just would hate to see you spend money on a part that isnt broken. I plan on getting the relocation bracket from woods when I get some cash saved up. Happy Jeepin!
Let me clarify that it was just a slight adjustment needed. The SS only needed about half a centimeter of extra clearence to clear the trackbar bracket but in doing that I had to rotate it downward on the tie rod end to where it was about and inch and a half lower than the tie rod. It wasn't really "low" to the ground so to say but it was much more vulnerable to being hit by rocks than the factory SS was. I would take a picture but I'm out of town until the weekend.
Wayoflife you are right about the bends in the tie rod, i havent looked at the one that closely on the JK the one I had on my CJ-5 only had a bend on each end and was straight in the middle, not sure if it was stock or not.
