Teraflex sway bar links movement?
Old Apr 26, 2011 | 07:00 AM
speedy64vw's Avatar
Default Teraflex sway bar links movement?
I am curious as to if anyone has 3-4" lift kit from TF with their sway bar quick disconnects?
I was checking my alignment and checking torque on my suspension and I have notice my sway bar links have movement up-and-down like I dont have enough grease in them.... I greased them up and it just comes out everywhere an I wiped clean, thinking there is enough?
No major noise when driving over bumps, but I do notice a bit of movement; like a small clunk feel... Possibly the sway bar links?
Any info or suggestions?
Old Apr 26, 2011 | 01:32 PM
speedy64vw's Avatar
Um bump...
Old Apr 26, 2011 | 02:03 PM
JK-UTE's Avatar
I run a TF 4" short arm kit and my QD's are working just fine. No problems like you are reporting. Wish I could give you more feedback... Good luck!
Old Apr 27, 2011 | 05:53 AM
speedy64vw's Avatar
Anybody else have movement right out of the box? I just want to make sure that this normal with disconnect style links...?
Old Apr 27, 2011 | 05:52 PM
speedy64vw's Avatar
Anyone have a recommendation as to what I should do... Not sure if this is normal?
Old Apr 27, 2011 | 05:54 PM
JK.nick's Avatar
Have you contacted teraflex on here? I'm sure they will be more than happy to help you out.
Old Apr 28, 2011 | 10:20 AM
racin444's Avatar
Installed my Teraflex disconnects with no grease in them and I never had this problem.
You wanna take a picture of how you mounted them? Im thinking that might be your problem.
Old Apr 28, 2011 | 11:18 AM
speedy64vw's Avatar
Installed them dry when they have grease fittings on them is odd... But if it works!
I greased mine all full and I'm pretty sure they are installed correctly, as I did read the instructions and saw pics of correct installation.
I dunno we'll see what Teraflex says
