Teraflex....track bar bracket question
I have a 3" lift and need to center the rear axle. Will the 2 - 3" rear track bar bracket center the rear axle good enough, or is it better to get the adjustable track bar?
Ok, teraflex has one bracket for 2-3" lift for around $33 and then the one that is in the link above for 2-6" for around $99. What is the difference, and if I have a 3" lift, would the $30 be ok?
i believe one is a basic drop bracket that comes off the frame mount (the first) and the other is the big bracket that attaches to the axle and is braced in. the later has multiple mounting points and so you can set your track bar to where you need it. for your purposes, the $30 one should be fine.
if you can afford an adjustable track bar, that would be the better way to go. if not, the drop bracket will help get it very close to center.
The #1954777 TB bracket will work with 2.5" and higher lifts. And unlike other designs, it doesn't need a brace or tears off your stock brackets.
http://www.teraflex.biz/products/jk-...inch-lift.html
Make sure bracket comes with a brace though.
