Teraflex....track bar bracket question
Old Jan 31, 2009 | 12:17 PM
In5ane's Avatar
Default Teraflex....track bar bracket question
I have a 3" lift and need to center the rear axle. Will the 2 - 3" rear track bar bracket center the rear axle good enough, or is it better to get the adjustable track bar?
Old Jan 31, 2009 | 12:22 PM
Jusaplaya's Avatar
It should be fine... Make sure bracket comes with a brace though.
Old Jan 31, 2009 | 12:24 PM
In5ane's Avatar
not familiar with the brace...can you explain why? also, can you point me to one?
Old Jan 31, 2009 | 09:29 PM
BIGJ's Avatar
Smile
here you go
https://www.jk-forum.com/forums/show...acket+teraflex
Old Feb 1, 2009 | 09:18 AM
In5ane's Avatar
Ok, teraflex has one bracket for 2-3" lift for around $33 and then the one that is in the link above for 2-6" for around $99. What is the difference, and if I have a 3" lift, would the $30 be ok?
Old Feb 1, 2009 | 09:25 AM
wayoflife's Avatar
JK-Forum Founder
if you can afford an adjustable track bar, that would be the better way to go. if not, the drop bracket will help get it very close to center.
i believe one is a basic drop bracket that comes off the frame mount (the first) and the other is the big bracket that attaches to the axle and is braced in. the later has multiple mounting points and so you can set your track bar to where you need it. for your purposes, the $30 one should be fine.
Old Feb 1, 2009 | 09:29 AM
In5ane's Avatar
thans so much for your help!
Old Feb 1, 2009 | 10:34 AM
TeraFlex's Avatar
Sponsoring Manufacturer
The #1954777 TB bracket will work with 2.5" and higher lifts. And unlike other designs, it doesn't need a brace or tears off your stock brackets.
http://www.teraflex.biz/products/jk-...inch-lift.html
Old Feb 1, 2009 | 10:49 AM
In5ane's Avatar
I actually just ordered the one that mounts to the frame...the $33 one. That one shouldn't need anything else with it..right?
