Tereflex Question
Old Apr 11, 2011 | 11:47 AM
Monte417's Avatar
Default Tereflex Question
Just installed the 2.5 coil lift and noticed that the rear brake line bracket is rubbing on the rear sway bar. Is it mounted in the wrong place or wrong way? Is anyone else having the same issue? Not sure what to do about this
Name:	sway bar rubbing.jpg
Old Apr 11, 2011 | 11:55 AM
Battlefrog's Avatar
Is that after relocating it with the extension.. I have 2.5" and my break line sits fine. Almost looks as if you need to adjust your sway bar...
Old Apr 11, 2011 | 11:56 AM
Battlefrog's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=148835"/>
Can you take a side angle pic.....
Old Apr 11, 2011 | 11:57 AM
Battlefrog's Avatar
I may be wrong, but it looks like you have it mounted wrong. The lip us supposed to sit inside the frame to secure it...
Old Apr 11, 2011 | 11:59 AM
TCORUM's Avatar
quick pic of mine
Old Apr 11, 2011 | 12:04 PM
Battlefrog's Avatar
Originally Posted by TCORUM
quick pic of mine
His mount is sitting awfuly low compared to yours...
Old Apr 11, 2011 | 12:08 PM
wazooz2424's Avatar
OP, take some better pics. more than likely, something is installed/adjusted incorrectly.
Old Apr 11, 2011 | 12:10 PM
Battlefrog's Avatar
X2.... Can you take a pic of opposite side as well...
Old Apr 11, 2011 | 12:42 PM
Monte417's Avatar
Default here you guys
ID:	148867Click image for larger version
ID:	148866Click image for larger version
ID:	148865Click image for larger version
Old Apr 11, 2011 | 12:45 PM
Monte417's Avatar
wait a minute. Its mounted backwards isnt it
