Terraflex Rear Trackbar Bracket
Currently both my axles are shifted toward the driver side. My rear track bar is using higher bolt hole and I hAve the option of using the bottom hole. By using the bottom hole will this shift my axle more towards center? By using the bottom hole am I compromising anything? Geometry is telling me yes just want to make sure before I do a lot of work in the garage in 110 degree weather.
Thanks
Thanks
Yes it will. Ideally you want the rear TB up as high and level as possible. But in order to actually center the axle lift height (rear) and the amount raised have to match.
Superlift has a track bar that will work to center the axle and only cost $100
Thanks kjeeper10, I suppose I need to find a trackbar that is shorter than the stock one to correct for this so I can use the top hole.
I'm a bit confused still, I replied in your other post about the axles being off center... You did a 2.5" coil lift right? And the rear track bar bracket raised the trackbar 2.5" right? When I did exactly the same thing, I couldn't even line the trackbar bolt hole up with the new bracket's hole without moving the frame/axle. Did this happen to you?
I'm in Scottsdale too if you want another set of eyes on it before doing anything. I just went through this two weeks ago myself.
Ok wait I read some of your other posts and in the rear you have spacers and the coils? That could be why you aren't lining up with using just the bracket, as the post above me said the height you raise the trackbar should match the height you lifted by.
