TF 1.5" Spring Level + RE .75" Rear Coil Spacer
Old 07-07-2015, 11:33 AM
Flexy's Avatar
Default TF 1.5" Spring Level + RE .75" Rear Coil Spacer
I have a new set of 33" BFG AT KO2 sitting in the garage while I wait for my wheels to be delivered. I don't like the look of 33's on stock height, nor do I like the look of 33's with 2.5" (3-3.5"net) lift. So my answer seems to be to go with a 1.5" coil lift.
I found the TeraFlex 1.5" spring lift would give me the height I'm looking for, but it will remove the rake. So, I'd also like to add a .75" puck to the rear coil to maintain close to factory rake. When all this is complete I will end up with 2" lift in the front and 1.75" lift in the rear.
I'm new to the jk world, but used to wheel tj's back in the day. What are your thoughts on my proposed setup? Are there any critical errors I'm missing?
BTW: My JK is a 2dr.
Old 07-07-2015, 02:04 PM
Emptied Each Pocket's Avatar
You may find the 1.5" coils to be a bit stiff if you aren't armored. Otherwise, the set-up sounds good to me. I ran the Teraflex 1.5 coils for a while and they withstood everything I threw at them. I came out a little more than level, but have factory front bumper and no winch.
Old 07-08-2015, 07:30 AM
Flexy's Avatar
Thanks for the insight. I'm also running factory bumpers and no winch. I'm hoping the .75" rear puck will keep me from being nose high.
Old 07-08-2015, 02:05 PM
No problem. I'm pretty sure you'll sit very close to level with that set up.
Quick Reply: TF 1.5" Spring Level + RE .75" Rear Coil Spacer
