TF 2.5" lift & control arm help
I installed the 2.5" TF lift with shocks about 2 yrs ago and ever since the Jeep has had that flighty feeling at highway speeds which I've grown used to. I want to buy a set of TF adj. lower arms but after reading through countless posts I'm finding hard to determine if the arms will help my handling. I mean, all the posts I seem to be reading are from those who have a minimum of 3" of lift. I've also read that with a 2.5" lift, the arms won't do much. Is this true?
Get them, you won't be sorry. My lift started out as a TF 2.5 (changed to OME HD after adding bumpers) and the adjustable lower control arms return the steering to a stock feel. I set mine at 23" and was happy with the handling.
I run Skyjacker 2.5" springs and shocks with a JKS adjustable trackbar up front. Right now i only have a relocation bracket on the stock rear trackbar. Handles beautifully. Goes 75mph beautifully. My only complaint is a bit of a rough ride. This i attribute to poly bushings and kevlar sidewalls.
I will be looking into these AEV brackets.
